Can't find VATS wire!
#16
Re: Can't find VATS wire!
Car is completely original as far as I know. My cousin gave it to me and the last time he tried to start it, it fired right up. That was about a year ago though. He lost the key, that's why I replaced the ignition lock.
#19
You just join the connector terminals with a piece of wire to jump the clutch switch.
#21
when was the last time the car ran? did it run before you put the key switch in? did it sit for a long time?
#22
Well, I looked through the entire chiltons book at the electrical prints and the first year with vats was 1989. Also if you have access to the STANDARD CATALOG OF CAMARO 1967-2002 COPYRIGHT 2002 BY JOHN GUNNELL it states on page 127, 3rd sentence says the pass-key theft deterrent system was added.
#25
so it has not been turned over in more than a year if i understand that correctly. make sure you can turn the engine over by hand. if it sat outside it is possible that it could be siezed, but very unlikely. you should be able to use a socket and ratchet or wrench on the crank pulley to turn it over. if it does you need to find a way to check the starter. it may be a little nerve wracking to jump relays and such if you've never done it before, but all it takes is one time to learn how easy it is and you'll be over that fear soon. Shoebox told you how to do it.
07-04-2005 05:00 PM
Rich_z28
08-29-2002 10:44 PM
