a/c bypass
Old 06-23-2011, 12:22 AM
twistedbowtie's Avatar
a/c bypass
i did a a/c bypass on my 1995 z28. my question is can i remove the small radiator lookin thing agains the radiator? sorry i forgot its name. im pretty sure i should be fine but wanted to make sure before removal
twistedbowtie is offline
Old 06-23-2011, 05:27 AM
Re: a/c bypass
The A/C condensor sits in front of the radiator. It can be removed if you delete the A/C system. Be sure to seal the ducting in front of the radiator securely to the radiator, or air will bypass the radiator and you will overheat.
Injuneer is offline
Old 06-23-2011, 11:00 AM
Re: a/c bypass
okay thanks alott fred.
magman
04-15-2016 03:08 AM
68camaroboltz
10-05-2015 01:46 PM
colts0455
10-04-2015 09:47 PM
football4life
10-04-2015 07:48 AM
Rod Bender
25
09-16-2015 01:47 PM
Quick Reply: a/c bypass
