!brake light/ traction lights flickering
Old 12-15-2006, 11:38 AM
transAMdriv3r's Avatar
In my 94 Ta, the dash lights (brake and traction lights) are flickering...sometimes they will stay on and some times they will flicker and less often they will not even appear. what gives?
thanks for lookin'
greg
transAMdriv3r is offline
Old 12-15-2006, 12:16 PM
teke184's Avatar
check the ABS sensor on the rear wheel...could be lose or corroded
teke184 is offline
Old 12-15-2006, 01:15 PM
OBE1 95Z28's Avatar
Could also be a dirty ground connection at the ground post located on the passenger side inner fender liner, next to the red power post.
OBE1 95Z28 is offline
Old 12-15-2006, 04:28 PM
2000GTP's Avatar
Originally Posted by OBE1 95Z28
Couls also be a dirty ground connection at the ground post located on the passenger side inner fender liner, next to the red power post.
When I had a similar problem, that was the solution. Both the power posts and the ground posts were caked with corrosion so I cleaned up everything real good with a wire brush and the problem was solved.
2000GTP is offline
Old 12-15-2006, 05:31 PM
ok, ill check it out tomorrow...thanks guys
dluna333
15
03-13-2015 12:30 PM
rwferguson43026
02-06-2015 10:06 AM
squarehead
01-15-2015 07:02 PM
AlaskaZ28
01-01-2015 12:30 PM
Quick Reply: !brake light/ traction lights flickering
