"Brake" light comes on, need advice
Old 05-22-2004, 03:01 AM
Hood_Lum's Avatar
After changing to steel braided brake lines my red "BRAKE" light comes on if I step on the pedal all the way.
Does this mean I didnt bleed the brakes enough or is it something more serious?
Oliver
Hood_Lum is offline
Old 05-22-2004, 09:53 PM
Hood_Lum's Avatar
TTT
Hood_Lum is offline
Old 05-23-2004, 07:55 AM
The "BRAKE" light comes on for uneven pressure in the front and rear braking systems, or for the e-brake lever. I've heard of people getting the light, correcting a leak or air problem, and then having the light stay on, since the "balance" switch is stuck in one position. Might want to check Shoebox for the cure. I think you might need to really press on the pedal as hard as possible to free the switch up, but I'm not sure of that.
Injuneer is offline
06-06-2015 08:27 AM
jj_burchiel
03-21-2015 12:51 AM
transam_388
03-15-2015 11:53 AM
captcorvette
03-07-2015 12:37 PM
David Dorris
01-17-2015 08:10 PM
Quick Reply: "Brake" light comes on, need advice
