bcm still chimes wen im out of car (no signal )
Ok I made a post few weeks ago. I said my Bcm chimes when I touch it. Well I see that its not my bcm wires. I hold them very tight. An touch the bcm with a screw driver it still chimes 2-3times... my car has no signal. It cranks fine.. #fuel pump doesnt come on.. coil doesnt spark. Icm is good. I primed my fuel pump an it works.. brandnew Pcm. Still nothing. . I was told if my bcm chimes with no key or small touches. Then its #baddddddd???? #shoebox #helpme man
Re: bcm still chimes wen im out of car (no signal )
Generally a good idea to continue the old thread, rather than start a new thread about the same, ongoing problem.
https://www.camaroz28.com/forums/gen...signal-880113/
The earlier thread confirms your car is a 1997.
By "no signal"you explained in the earlier thread that you meant "no fuel pump signal." Appears this is still a problem, and the engine will not start????
In the earlier thread you indicated that when the engine did run, it continued to run when the ignition was switched to "off".
Yes I made a new post cause no1 respond. Sorry about that. But it had stopped staying on for a few months. But my main problem is that my bcm chimes when I touch it. Really bad shortage seems like.. an its not my wires because I will hold them tight an touch the box. It still chimes. Thanks for responding
