Bad erg valve?
Old 12-17-2013, 11:32 AM
dallasz2876's Avatar
Bad erg valve?
I had someone tell me a bad erg valve on a lt-1 could cause combustion gases to enter the cooling system, I haven't heard of this but I'm not a mechanic, is this true?
dallasz2876 is offline
Old 12-17-2013, 02:45 PM
Re: Bad erg valve?
Incorrect. The EGR valve is bolted to the intake manifold, and the exhaust gas path flows directly into the intake manifold, using the same holes in the intake runners as the idle air. The LT1 intake manifold is totally "dry" and has no coolant passages at all. No way the exhuast gas could get in the coolant, even if the valve is faulty.
Injuneer is offline
Old 12-24-2013, 09:34 PM
Dennyj1992's Avatar
Re: Bad erg valve?
I'm about to change the gasket on mine here on Thursday evening.
Quick question on that. Could a bad gasket or the part itself cause the car to idle rough?
Dennyj1992 is offline
Old 01-05-2014, 11:08 AM
Re: Bad erg valve?
Yes a bad egr valve could cause rough idle.
HectorM52
07-30-2017 11:46 AM
Jazsun
12-29-2014 12:14 PM
BIGCOWL-IMP
12-19-2014 06:59 AM
Quick Reply: Bad erg valve?
