Asr?
Asr?
I have a switch next to the fog light switch called ASR. If it's on it will make the gas pettle release if the tires spin out when wet or flooring it etc etc. Well it doesn't show up on the dash anymore. Any idea what i can look for or is there a way i can just disconnect it altogether? I know it's more dangerous to have it constantly off but i don't care right now. Thanks for any input guys
The ASR stands for Automatic Slip Reduction (if I remember correctly) but is just a fancy way of saying traction control. I believe everytime you turn the car off, it resets it to its normal state which should be enabled. You should be able to check that pretty easy by just going out and trying to spin the tires. You may want to check your fuse box as I believe there is a seperate fuse just for that system.
Well i tested it out and it seems to be working. It is always on when you first turn on the car so hitting the switch once will make it off, and it is working just no light on dash anymore that tells you when it's off. I'll check fuses and go from there
WobblySausage
10-07-2015 10:09 AM
dluna333
15
03-13-2015 12:30 PM
