alarm keeps goin off!
Re: alarm keeps goin off!
Mine did it, so i cut the wires at the little sound thing, cuz i had no idea who installed it or where the hell all the wires were for it (it was a rather crappy alarm anyways). I got lucky because the car actually still starts and runs no issues (AKA i would not advise doing this), might want to take it somewhere that knows what there doing and have it checked out.
On the stock alarm system if it goes off by itself right after arming usually it's a sign the shock sensor above the spare tire is going bad. You can try turning the sensitivity down, or just unplug it and see if it stops - if it does that's most likely the problem.
I had to do the same thing last year, never messed with it, never got it wet or anything - still had the factory seal over the ****. Still goes off if the car is disturbed but takes more now, one of these days I'll get a new sensor.
Originally Posted by Jeremy_30th
Same thing here to. set it and it sounds 2 times but here is my twist it only does it when it has rained and the car got wet
MichiganSkip
08-06-2015 09:38 AM
