AC abruptly quit - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 07-13-2013, 10:02 PM   #1
Ryan96WS6's Avatar
AC abruptly quit
Driving around today the air conditioning was working fine. All of a sudden it just started blowing hot air. I went home and checked the system pressure. The pressure was 75 PSI, in the warning zone on the gauge. Now when I select an AC mode the whole car shakes.
My guess is a blockage in the line somewhere. Also sounds like a problem I will have to take it in for, considering the freon.
Anyone had this problem before?
Ryan96WS6 is offline   Reply With Quote
Old 07-13-2013, 11:18 PM   #2
Re: AC abruptly quit
If the refrigerant gets low enough the PCM will cut off the compressor. How did you check the pressure. It has to be checked with the compressor running. If the PCM cuts off the compressor it has to be reset before it will work again. Either pull the PCM fuse for a few seconds or unhook a battery cable. 75 PSI sounds like it was checked with the compressor off. 75 PSI is too high for a low side pressure and too low for a high side pressure.
Turn on the a/c while looking at the compressor clutch and you can see if the compressor starts. You should be able to see if it is making noise or vibrating. If it is I wouldn't run it any more until you get it checked. If your refrigerant has been leaking, oil leaks out with it. Over time, if you keep refilling without adding oil, the compressor can lock up due to lack of oil. If it seems to be working ok, you could add some refrigerant and see if it starts cooling normally.
rngilliland is offline   Reply With Quote
Old 07-14-2013, 03:20 PM   #3
Ryan96WS6's Avatar
I checked it with the compressor on. I was about to pump in a little more R134 if it needed it. I have added refrigerant twice in 10 years so it is possible some oil has escaped as well. I am out of town, so further diagnosis on the clutch will have to wait until next week. At this point I suspect the clutch was engaging and there is a problem with the compressor that is causing the car to shake when it is on.
Thanks for the input.
Old 04-10-2014, 03:00 PM   #4
Ryan96WS6's Avatar
Just wanted to follow up on this thread with the fix for this problem.(In case someone else has it) It was the compressor clutch. It went bad and was no longer engaging or disengaging properly. The vibration was caused by the compressor clutch spinning off center as it was driven by the belt.
Just this week got it in to get fixed. Glad to have it back in normal driving condition after all this time.
Old 04-11-2014, 03:20 AM   #5
Thanks for the update, I have a compressor clutch that I suspect is going and it's good to have the additional info you've provided here.
Keenan is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Hoping for Suggestions KYWes LT1 Based Engine Tech 5 09-26-2015 09:49 AM
help diagnosing problem greenzee28 LT1 Based Engine Tech 6 09-25-2015 05:29 PM
stock heads and supercharger DelSoto Forced Induction 4 09-19-2015 06:31 AM
4 Cyl Turbo Drifting Video cmsmith 2010 - 2015 Camaro News, Sightings, Pictures, and Multimedia 0 09-14-2015 10:09 PM
94 Z28 Automatic transmission - engine stall - No codes present Nayr LT1 Based Engine Tech 3 09-05-2015 07:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
