Turn signal/hazard
Old 11-09-2013, 01:06 PM
Chet1185's Avatar
Turn signal/hazard
is there just one flasher or are they separate?
95 TA
Sent from my R800x using Tapatalk 2
Chet1185 is offline
Old 11-09-2013, 04:30 PM
Re: Turn signal/hazard
You need to start using Shoebox's site:
http://shbox.com/1/flashers.jpg
Injuneer is offline
Old 11-09-2013, 09:10 PM
Chet1185's Avatar
i'm always on there, just didn't think too look.
Chet1185 is offline
Old 11-13-2013, 09:03 AM
Chet1185's Avatar
Swapped flashers and still no turn signals. Just swapped my good switch into this column and still no turn signals. Fuse is good, all wires look good. Hazard lights work and all bulbs light up. What else is there that can keep the turn signals from working? Would a broken brake light switch cause this?
There is one plug under the dash that I can't plug into this column but I assuming its just for the stereo controls on the wheel.
Sent from my VTAB1008 using Tapatalk 2
Chet1185 is offline
Old 11-14-2013, 01:34 PM
Chet1185's Avatar
No reverse lights either
Chet1185 is offline
Old 11-14-2013, 10:06 PM
There are some lighting schematics on my website that might help.
1995 4th Gen F-Body Exterior Lights
http://shbox.com/1/back_up_lights.jpg
shoebox is offline
Old 11-14-2013, 11:13 PM
Chet1185's Avatar
I see that the fuse is the link for both. Where does the fuse get power?
Sent from my LG-LS860 using Tapatalk
Chet1185 is offline
Old 11-15-2013, 03:18 AM
Chet1185's Avatar
Does the ignition switch supply the power to the fuse?
Chet1185 is offline
Old 11-15-2013, 09:01 AM
Anything that says "hot in run" is going to be powered through the ignition switch. It would be a simple thing to see if you have power at the fuse.
shoebox is offline
Old 11-15-2013, 10:00 AM
Chet1185's Avatar
Sorry that i am a noob,
Chet1185 is offline
Old 11-15-2013, 11:39 AM
Chet1185's Avatar
Got it. One of the prongs in the ignition switch was bent. Thanks for the help
Chet1185 is offline
Maroz28maro
07-29-2016 07:45 PM
mark0006
08-17-2015 09:56 PM
jasonduaine
06-04-2015 09:29 AM
CaRParts102
12-06-2014 08:45 AM
formula79
26
08-05-2002 12:21 PM
Quick Reply: Turn signal/hazard
