A4 car won't shift out of park after sitting...not trans, it's the shifter
Old 10-08-2006, 05:32 PM
U Can't Z Me's Avatar
Hey guys,
I have a 95 Z28, A4 car. When the car has been sitting for more than a couple hours it will not shift out of park when I press the brake. It isn't a trans issue, it's the shifter itself. I cannot get the button to depress without beating on it and wiggling it.
Is there something I can do to adjust/fix this? It's really annoying, especially 1st thing in the morning.
Let me know.
Thanks,
Eric
U Can't Z Me is offline
Old 10-08-2006, 06:00 PM
Kris93/95Z28's Avatar
Re: A4 car won't shift out of park after sitting...not trans, it's the shifter
I don't know the name of the part, but it sounds like its somewhere in the system that requires you have the brake depressed to remove the transmission from park.
Kris93/95Z28 is offline
Old 10-08-2006, 06:03 PM
Try disconnecting the electrical connector to the brake/trans interlock solenoid (under the shift quadrant indicator) to see if it is not disengaging and holding you up.
shoebox is offline
Old 10-08-2006, 06:05 PM
Here is Shoebox's reply from when I asked a similar question years ago for my 1995 Z28:
Originally Posted by shoebox
Could be that the BTSI (Brake Transmission Shift Interlock) solenoid is acting up. Try unplugging the electrical connector to it and see what happens. It is the black thing on the left in this pic, under the shifter plate. When unplugged, you will be able to shift out of park at any time when the key is ON, so beware.
Old 10-09-2006, 07:05 AM
Lt1 and Ls1's Avatar
I have the same problem. In fact I posted last week. If you let the car warm up about 10 minutes it will be ok. It is irritating when it does it. I was hitting on mine and BROKE my fingernail OFF, not just the tip, the whole thing. Anyway shoebox has a fix for it He is awesome!
Lt1 and Ls1 is offline
Old 10-09-2006, 08:17 PM
LastZ4ME's Avatar
Isnt it a pisser in the morning when it's cold. After about 5 to 10 min, mine will eventually shift. Every 1995 camaro has either a bad Shift Lock Solenoid or a bad Coolant level sensor, or both
LastZ4ME is offline
Old 10-10-2006, 07:40 AM
Yep. Gotta love our f-bodies Dont feel bad about the 95 my 98 has both too
Old 10-18-2006, 08:59 AM
PLUM CRAZEE's Avatar
Have the same problem only when the weather is cold and found and easy way to get it to shift. Pull out the ash tray and you will the shaft going to the BTSI solenoid it has a black plastic cover on it. ( see pic in post 4 of this thread) Pull up on that shaft with your finger while pushing the button on the shifter. Works every time for me.
PLUM CRAZEE is offline
Old 11-17-2007, 10:34 AM
killur_z's Avatar
i love this forum...every problem i have ever had with my car has been addressed on this site...i wish I could find a site like this for my wife's minivan(93 chevy astro)
killur_z is offline
Old 11-17-2007, 10:49 AM
1995blackttopta's Avatar
my 95 T/A was doing the same thing a few weeks ago, but since the trans rebuild its been fine. i wonder ifi t was loose or something and was adjusted correctly during the trans rebuild (no this is not why i had the trans rebuilt, lol.....)
1995blackttopta is offline
Old 12-04-2007, 06:59 PM
19blackta98's Avatar
My 1998 T/A does the same thing. I know its not the brake thing because I unhooked it. Anyone else have any fixes?
19blackta98 is offline
Old 04-02-2008, 10:09 PM
93DGTA's Avatar
My question to this is can you do away with this? Car is track car only
93DGTA is offline
Old 04-02-2008, 11:04 PM
Sure, just don't connect it.
shoebox is offline
Old 04-02-2008, 11:13 PM
93DGTA's Avatar
Thanks shoebox one less thing for me to worry about
93DGTA is offline
Old 06-26-2009, 01:04 AM
Expense95's Avatar
I'm having the exact same problem with my 95Z. I disconnected the BTSI solenoid and now there are no problems. Does anyone know how much it would cost to replace this part? If it's really not necessary, or if it wont set a SES code, I'll probably just leave it disconnected.
Expense95 is offline
Quick Reply: A4 car won't shift out of park after sitting...not trans, it's the shifter
