99-04 stang GT vs. LT1
#31
Re: 99-04 stang GT vs. LT1
Originally Posted by Cman
Yeah, Yeah you're right it's direct drive not high gear. At least I got the proper gears correct for dynoing.
I've been working some late shifts lately so, CUT ME SOME FRIGGIN' SLACK!!!!!!!!!!!!!!!
Tony
Tony
No prob. I was just being overly technical anyway. You got the gears to be in right.
#32
Originally Posted by urbaNHunter44
A stock LT1 of any year and model package should dyno 260ish rwhp for an A4, 270ish rwhp for an M6, having slightly over 300 at the flywheel. The only cars that were rated CORRECTLY by GM, were the 96/97 WS6/SS. They'll trap 100-102 on average.
The mustang you're describing, has 265, which is rated accurately. They will dyno near 240 rwhp and run mid 14s on average, trapping 95-97.
Tell me which one is going to win
The '05/'06 New Edge Mustang finally stepped up to the big 300. Welcome to 1993, Ford. They will typically trap 100-102, however they have an advantage over an LT1 from a dig. They can hit low 1.9 60 foots completely factory stock. I've seen one person get a 1.89. This means nothing on the street however, as prep is non-existant.
From a roll an LT1 is even with an '05/'06 stang. It will have no problems with earlier years however.. unless you want to go back to the late 60s, early 70s
bone stock lt1 a4's dyno 240ish...
#33
#37
Originally Posted by Honda Hunter
P.I > LT1 The true stangers will know what that means.
#38
I would choose a P.I Mustang over a LT1 any day. The LT1 Camaros are so outdated in styling and engine wise. I could make more power and safer power in a 99+ mustang. I'm so ready to duke this one out.
#39
The only way you are going to see over 400hp at the wheels with a P.I. 2v 4.6 is with a good Vortech S-trim blower, intercooler, full exhaust, and a Bullitt intake. Thats quite an investment there, but probably the cheapest way to see 400rwhp. At that power level, you have to be extremely careful with the tuning, because it will be quite easy to send a piston to hell. A Steeda representative told me personally that at that power level I would be very prone to loosing a piston or having problems with head gaskets in stock trim. Also, the t45s and the t3650s might survive at that power level for a decent bit of time, but the first time someone gets aggressive with a 4r70w at that power level and the trans is going to give out. 3-4 band is going to give out almost immediately.
An LT1 fbody can make over 400rhwp naturally aspirated, on the stock bottom end, for alot cheaper, and not have to worry about having to forge the stock bottom end at that power level. A D1SC Procharger on an otherwise stock LT1 can push the power levels of the car up to and past 400rwhp, with very little in supporting mods done to the car otherwise. Heads/cam or blower on an LT1 would be much cheaper routes to reaching that 400hp mark than on the 4.6. The 4l60-Es are a hit or a miss. I have heard of some of them giving people trouble at this power level, I have heard of others behaving fine. The t56s would live and breathe at this power level with no problem.
An LT1 can see up to 396s cubes on the stock block (for practical purposes), good luck getting more than 5.3 liters out of a 4.6. All of the biggest power 4.6s I hve heard of are running some pretty huge boost numbers out of big blowers or turbos; try running some of those same FI devices at similiar outputs on an LT1, and see which makes more power.
Sorry dude. I had a Mustang GT for well over a year, and over that time I learned ALOT about Mustangs. Talked to alot of guys, hung out with alot of people, and spoke with alot of aftermarket technicians. So I am not spouting out crap here. I also am not really that huge of a fan of the LT1. I got rid of my GT because 1. it was in an bad accident, 2. i wanted an LS1 to replace it because I feel the LS1 is superior in almost every way. If the LT1 was still in the Camaros I probably would have picked up another Mustang. I am just trying to look at this objectively, and I don't think the 4.6 has the potential in either street or race trim that an LT1 does.
#41
Originally Posted by Camarocracy
The 02-04 GT's do look good though.
#43
Originally Posted by RussStang
OK, well you are probably going to have to. The styling I will give to you, because I don't really like the Camaro's 93-97 front end very much.
More power out of the 4.6 though. Sorry, nope.
Dont take anything Ive said as a flame. I'm not trying to come off as a a-hole.
#44
I knew it would only be a matter of time before this thread turned into a big pissing contest.
Why don't you guys stick to what was originally asked in the subject rather than how one motor can kick the crap out of another with certain mods and vice versa. My engine is more efficiant than yours blah blah blah. And WTF does styling have to do with which one is faster.
Again:
STICK TO THE SUBJECT.
The guy wants to know stock for stock who would win. The LT1 has the power advantage and the GT has the weight advantage. Its a drivers race with the LT1 having a slight advantage.
This ought to be posted in the Mustang forums so you get their pantys wadded up too.
Again:
#45
Cant answer the question without getting into it. It's like asking what taste better coke or pespi. Have to get dirty and explore the detail instead of making it a yes or no question. Life isnt that simple.
