98 speedo
Old 12-22-2014, 04:41 PM
blac94Z's Avatar
98 speedo
Can i use a 98 speedo in my 94 z28 with a 94 dash or will i need to swap everything ?
blac94Z is offline
Old 12-22-2014, 09:58 PM
maybe2fast's Avatar
Re: 98 speedo
93-97 only in an LT1 car
maybe2fast is offline
Old 12-23-2014, 09:20 PM
blac94Z's Avatar
Re: 98 speedo
So why does the 97 have the same speedo as a 98+ cars ?
blac94Z is offline
Old 12-24-2014, 02:41 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: 98 speedo
I believe this is how it is, according to the service manuals:
97 Firebird is the same connector as 98 F-bodies
97 Camaro and earlier are different from 98
GaryDoug is offline
Old 12-24-2014, 03:26 PM
blac94Z's Avatar
Re: 98 speedo
so basically i have to either find a 97 z28 cluster or a 98+ firebird cluster ? and is this bc it is obdII or is it just bc
blac94Z is offline
Old 12-24-2014, 04:29 PM
Prominent Member
GaryDoug's Avatar
Re: 98 speedo
Nothing from 98 up will work in your 94 as far as I know (no expert here). No Firebird cluster will work either. I think a 94-97 Camaro will work like was stated before. Not sure about 93. I am basing al this this on what I see in the service manuals that shows the 94 and 96 Camaro having a different connector from any 98, and different from any year Firebird. I have no experience with these parts.
GaryDoug is offline
Old 12-24-2014, 06:32 PM
Re: 98 speedo
Not sure why this is in "Parts For Sale".
Moving.
Injuneer is offline
Old 12-29-2014, 01:53 PM
blac94Z's Avatar
Re: 98 speedo
oh i get it so i will have to swap it with a 97 cluster ? will it fit in my 94 dash ?
blac94Z is offline
Old 01-13-2015, 03:47 PM
Zee man's Avatar
Re: 98 speedo
You can put a 97 dash cluster in a 93 through 96. But you will need to change out the dash and center
consol, and repin the cluster conector to the 97 style. Even though the cluster shape is the
same for 97 and up the
electronics are different for the
various guages in the 98 and up.
Zee man is offline
Old 01-14-2015, 12:15 PM
blac94Z's Avatar
Re: 98 speedo
i may have to do it that way what all do i need to re pin ?
blac94Z is offline
Old 01-27-2015, 02:09 PM
Zee man's Avatar
Re: 98 speedo
You need the connector for the 98 cluster, the plastic connector that came from the 98 . I believe the 94 and 98 connectors are shaped differently so the 94 wont fit in the 98 cluster.My car was done when I bought it, so I dont know which wires go where. You would need the wirring diagrams for both cars to do the repin. But it is doable.
Zee man is offline
Old 01-27-2015, 03:10 PM
blac94Z's Avatar
Re: 98 speedo
thankas but if i do it i would rather just put a 97 dash and cluster instead less of a headache this way right ?
blac94Z is offline
Old 02-10-2015, 11:02 AM
Zee man's Avatar
Re: 98 speedo
You still need to repin the harness for the dash .
Zee man is offline
09-27-2015 01:55 PM
mmf_1013
09-12-2015 08:56 PM
CamaroSS30thAnn
09-08-2015 04:43 PM
LazyLemming
08-29-2015 07:36 PM
4586
08-24-2015 11:04 PM
Quick Reply: 98 speedo
