98+ Parking Brake Shoes
Hey-
This is my first 98+ rear brake setup and they are noticeably different from my 94. The parking brake now has a separate set of shoes... Any preference on the best replacements? They seem to be all over the map price-wise.
Unfortunately I was already $150 into the rear brakes and had to put them back together to drive the car but will be pulling apart to replace these pads.
Thanks for any input.
Re: 98+ Parking Brake Shoes
Don't base it on how far you pull the lever up... 3/4 of the way up is where mine's always been. Pop the driver's side rear rotor off and take a look at the shoe before you spend the money.
Band Director-
Thanks for the input, but as I mentioned in the OP - I already had them apart and had to put back together. There is about 1/4" of material left on them.
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
Did you check the 98 service manual about this? There is a procedure to determine if the shoes need to be replaced. And it does not relate to the lining thickness.
http://www.mediafire.com/file/qzbtnv...bookmarked.pdf
By the way, the special tool mentioned can be replaced with an ordinary inside/outside measuring caliper.
