Fan Temp for V6?
Old 12-30-2016, 11:46 AM
Paul94Z28's Avatar
Fan Temp for V6?
What temps do the fans come on for the 3.8 V6? The t-stat opens at 195 as expected, but the car goes up to 210 and no fans yet...
Paul94Z28 is offline
Old 12-30-2016, 05:20 PM
Re: Fan Temp for V6?
Probably the same as the V8... low speed at 226*F, high speed at 235*F.
[EDIT] Verified above in the 2000 factory service manual.
Injuneer is offline
Old 12-30-2016, 07:32 PM
Paul94Z28's Avatar
wow - that seems hot. Have not been up that high given the temps outside are in the low 30s...
Will pay attention when it warms up a bit.
Old 12-30-2016, 09:40 PM
GM designed the engine to run at ~210*F. Best combo of low emissions and good fuel economy. That's why the middle of the gauge is where it is. A 195*F t'stat only starts to open at that temp. Doesn't fully open until about 210-215*F.
Injuneer is offline
Old 01-05-2017, 05:58 PM
peterpar's Avatar
Here's a copy and paste from the 1994 Service Manual for a 3.4L cooling fans:
OPERATION
The engine coolant fan is controlled by the PCM
via the coolant fan relay. A calibrated set of criteria
programmed into the PCM will energize the fan relay.
The following conditions control the fan:
• Engine Coolant Temperature (ECT) sensor
signal indicating 109°C (228°F) or greater will
turn the coolant fan "ON."
signal indicating 98°C or less will turn the fan
"OFF."
• The fan will turn "ON" if A/C is requested and
vehicle speed is less than 56 km/h (35 mph).
• If vehicle speed is greater than 113 km/h (70
mph) the fan is disabled and will not turn
"ON."
• If A/C is requested and refrigerant. pressure
sensor indicates approximately 20 psi or
greater the fan is turned "ON."
• When the PCM is operating in backup the fan
will be "ON."
• When any A/C DTC is set the fan will be "ON."
peterpar is offline
Old 01-05-2017, 06:57 PM
His question is about his 2000 3.8 V6 with dual fans.
Injuneer is offline
Old 01-05-2017, 07:42 PM
peterpar's Avatar
Excuse me Fred, I read it too fast and stop looking at the signature after seeing 1994 Camaro.
peterpar is offline
Old 01-05-2017, 09:52 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
By the way Fred, Pete is the guy who did the excellent work on the service manual bookmarks. I haven't posted that here.
GaryDoug is offline
Old 01-06-2017, 07:05 AM
Paul94Z28's Avatar
Appreciate the support guys - Thanks!
