'98 Ignition switch/VATS problem ?
I have a '98 Z28 and am having starting problems. All circuits are powered up with the key on but the starter won't engage, so I've pretty much narrowed it down to the ignition switch/key/VATS. When the problem began, the car would start intermittently/randomly, and when it wouldn't, it would usually start if I removed and reinserted the key in a slightly different position, usually requiring multiple attempts. I think perhaps that's a clue the VATS isn't seeing the resistance value in the key? This approach is becoming less effective and most times it won't start at all now. I've read the excllent VATS info on Shoebox's site, but the info is for LT1 cars. Can anyone tell me if the info, specifically bypassing the resistor pellet in the key with a like value resistor wired into the harness, is applicable to my '98 LS1? If not, any suggestions on how to verify the problem and cure without replacing the switch? Thanks,
Bob
Bob
Re: '98 Ignition switch/VATS problem ?
Originally Posted by 96formulaLT1
if its a stick check your clutch saftey switch.
Bob
Originally Posted by bobscogin
Thanks for the response. Should have stated it's an auto, not a stick. But it occurs to me that a defective neutral start switch could have the same affect. After playing around with shifter postion, it didn't seem to make any difference, while moving the key slightly did.
Bob
Bob
Originally Posted by Z95m6
If its Vats related you should get a security light. Are you getting the light? If not i'd look at ignition switch.
Bob
When I turn the key to the "on" position, all circuits power up, I can hear the fuel pump run momentarily and all the following dash lights illuminate: ABS INOP , LOW TRAC , Air bag, Security, Service Engine Soon and Check Gauges. After a few seconds, all go out (including security) except the "Check Gauges" and "Service Engine" lights. I'd expect those to remain illuminated with switch in "on" position and engine not running. When I then turn the key to the start position, the "Security" light does not come back on. If I'm understanding correctly, I think you're implying that if it was a VATS problem (switch not recognizing key), the "Security" light would come back on? Thanks,
Bob
Bob
Yes, if your car is anything like the LT1 cars if you have a Vats problem, like the car not recognizing the key, you will get a security light and not beable to start the car for 3 mins. It should explain the security light in your owners manual. I would suggest you look at the ignition switch in my opinion.
Bob
Bob
Better to start a new thread than digging up a 5 year old one that is not exactly like your issue. Yours could be ignition switch.
Oncomingstorm22
01-22-2015 07:15 PM
