Reverse lights not getting signal from transmission
Old 08-04-2013, 10:37 AM
canbaufo's Avatar
Angry Reverse lights not getting signal from transmission
...that appears to be the culprit of the problem. I posted this in the electronics forum but it's a REALLY slow forum. Anyway I'm quite sure that the problem is related to a sensor or wire coming from the trans, that's the long and short of it ...but I don't yet know how to fix that. If anyone cares to read about everything I've tried in detail (about 10 hours deep now) here's the post from the other forum, but I don't think there's any need to read all that:
https://www.camaroz28.com/forums/car...please-875155/
Just thought I'd walk away from it for awhile and try to get some help before putting more hours into searches. Thanks in advance to anyone that has time.
canbaufo is offline
Old 08-04-2013, 12:05 PM
Re: Reverse lights not getting signal from transmission
The backup light switch (not a sensor) is on the passenger side of the trans. It's the only electrical connection on that side. It's either a faulty switch or a loose wire.
Key on, you should have 12V on the brown wire at the switch harness connector (measure with a volt meter from the brown wire pin to ground on chassis).
With the connector on the switch, in any gear other than reverse, you should have 0V on the light green wire in the harness connector. When you shift it into reverse, you should see 12V on the light green wire.
Injuneer is offline
Old 08-05-2013, 12:02 PM
canbaufo's Avatar
Thanks a bunch! I'll try that out and see how it goes.
canbaufo is offline
Old 08-26-2013, 09:01 AM
canbaufo's Avatar
That (switch) was THE fix, thanks!
canbaufo is offline
Old 08-26-2013, 01:36 PM
Laymaster's Avatar
Where did you get the switch from and how much did it set ya back? I think I have the same issue.
Laymaster is offline
Old 08-27-2013, 08:20 AM
canbaufo's Avatar
Advanced had one for $11 ....I was shocked and pleasantly surprised.
canbaufo is offline
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
A's 91 Z28
12-07-2014 12:09 PM
CaRParts102
12-06-2014 08:45 AM
07-04-2005 05:00 PM
Quick Reply: Reverse lights not getting signal from transmission
