CamaroZ28.Com Message Board
CamaroZ28.Com Message Board (http://www.camaroz28.com/forums/)
-   General 1967-2002 F-Body Tech (http://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/)
-   -   97 Z28 slowww wiinnndowwsss (http://www.camaroz28.com/forums/general-1967-2002-f-body-tech-46/97-z28-slowww-wiinnndowwsss-875473/)
RJ Nomad 08-20-2013 01:28 AM
Just picked up a 97 Z28, the windows are moving very slow. I have to replace the driver side trim bezel, to keep the switch in place, as well. Do I need to pull the panels off, grease the gears and maybe clean the wiring, to get them to move a little faster, or could it be another issue? Thanks
shoebox 08-20-2013 01:39 PM
Re: 97 Z28 slowww wiinnndowwsss
Window motors are the first thing to go on a 4th gen. Anything you can do to make the window go up and down with less drag is helpful, but won't "fix" a tired motor.
Look at the top of the "How To's" section of my website (link in sig) for window help.
RJ Nomad 08-20-2013 02:24 PM
thank you shoebox, I appreciate the info
GaryDoug 08-21-2013 09:04 AM
The driver side window in my 98 was getting verrrry slow so I ordered a new motor. While awaiting delivery, I took off the door panel and noticed the grease in the short tracks was fairly hard and dry. I scraped it out and replaced it with fresh silicon grease. Now the window was much faster. That was 5 years ago and the replacement window motor I ordered is still in it's box in the garage.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
