Abs, tcs, trouble codes
Old 11-09-2013, 03:42 PM
Chet1185's Avatar
My abs inop light is on all the time. My tcs button won't light up, tcs off doesn't light on dash. Performance Trans button won't light up but its working according to the scan9495 software. I can't get that to show any abs codes. I am getting codes 26,27,77. I did do an egr delete.
Just swapped out a95 Camaro column into my TA and now the turn signals don't work. Are the turn signal and hazard flasher the same or are there 2 of them?
Sent from my R800x using Tapatalk 2
Chet1185 is offline
Old 11-09-2013, 03:57 PM
Chet1185's Avatar
Re: Abs, tcs, trouble codes
I just swapped the flashers and still the same. So am I left with the switch itself?
Chet1185 is offline
Old 11-09-2013, 09:43 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Originally Posted by Chet1185
My abs inop light is on all the time... according to the scan9495 software. I can't get that to show any abs codes.
Did you select the ABS scan option on the left side of the screen? Are there any values showing on the ABS tab? What version is the scan9495 app?
GaryDoug is offline
Old 11-10-2013, 03:34 AM
Chet1185's Avatar
I did click it but nothing happened. The program kept unselecting it. I downloaded it right when you made it and posted it.
Chet1185 is offline
Old 11-10-2013, 07:59 AM
Prominent Member
GaryDoug's Avatar
If the app is turning off the selection, then it can't communicate for some reason. The version date is in the upper corner.
GaryDoug is offline
Old 11-10-2013, 10:53 AM
Chet1185's Avatar
Ok. I'll check it then
Chet1185 is offline
Old 11-10-2013, 12:33 PM
Chet1185's Avatar
June 2013
Chet1185 is offline
Old 11-15-2013, 12:51 PM
Chet1185's Avatar
Got this fixed. Prong on the ignition switch was bent.
Sent from my LG-LS860 using Tapatalk
Chet1185 is offline
Old 11-15-2013, 12:57 PM
Prominent Member
GaryDoug's Avatar
Good for you! By the way, there have been many enhancements and improvements since June. You should download the newest version. You can keep the old scan9495.exe file in another folder if you wish.
GaryDoug is offline
Old 11-15-2013, 02:39 PM
Chet1185's Avatar
Sounds good, ill update then. Thank you
Chet1185 is offline
armedtrigger
02-24-2015 08:30 PM
David Dorris
01-17-2015 08:10 PM
squarehead
01-15-2015 07:02 PM
91Bird305
08-05-2002 01:39 PM
LT1
07-02-2002 08:27 PM
Quick Reply: Abs, tcs, trouble codes
