Passenger Side Mirror help
Old 05-16-2013, 07:11 PM
Laymaster's Avatar
I don't know how this happened whether it's just age or someone ran past my car in the driveway and hit my mirror but it's somewhat broken off the car. Do I need to replace the whole mirror or can I somehow get the inside bracket that the mirror bolts to? Pictures are attached if they are helpful. I can take more if it somehow helps.
Thanks in advance.
Laymaster is offline
Old 05-17-2013, 08:03 AM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: Passenger Side Mirror help
It looks like it is broken, is not repairable, and is hanging just by the wires. But you should remove it to examine the mount closer to see if it can be fixed. You may be able to remove it without removing the door panel if you can reach the electrical connector behind the panel after removing the triangular piece covering the mirror's mounting screws.
GaryDoug is offline
Old 05-19-2013, 12:00 PM
Laymaster's Avatar
Gary, thanks for replying. It was just hanging on by the wires before I tried to get it back on. I believe I have it on by 1 or 2 screws right now and 1 of the screw mounts is definitely broken on a plastic mount. Is the mount something separate? Are the plastic and metal brackets interchangeable?
Old 05-19-2013, 12:13 PM
Prominent Member
GaryDoug's Avatar
I have no idea. You now have more information/experience than I in this matter.
GaryDoug is offline
Old 05-21-2013, 10:25 PM
rv93's Avatar
unfortunately, ive never taken an f body mirror off, but ive taken some other gm ones off, and they usually have 3 studs molded into the plastic. its pretty common for the plastic frame to break. The one i worked on had one broken off, and the mirror was a bit floppy, but since it was an econobox and the owner didnt wanna spend to much money, i superglued the plastic back together, and it went in fine. This was 2 years ago, and still no issues. i think its worth a shot
rv93 is offline
Old 05-22-2013, 03:52 PM
Laymaster's Avatar
RV thanks for the suggestion on the super glue but I don't have the missing pieces.
camaro98_speed
04-22-2015 11:26 AM
alex5366
02-17-2015 10:43 PM
siguy
11-27-2014 10:07 AM
Quick Reply: Passenger Side Mirror help
