95 Z28 Sputtering
#16
Re: 95 Z28 Sputtering
Do you still have the stock dash gauge, functional? Did you possibly wire the digital gauge in parallel with the stock 1-wire sensor in the head? That would cause both the dash gauge and the digital gauge to read incorrectly.
#17
Yes sir, I still have the stock dash gauge. I ran one wire from the digital gauge to the sensor and one wire from the gauge to a power supply in my fuse panel to power the lights on the digital gauge.
#18
If both the stock gauge and the digital gauge are connected to the same one-wire temp sensor, it would seem the resistance of the circuits would be affected, throwing the readings of both gauges off. Each gauge needs its own one-wire sensor. There is the same threaded hole on the passenger side head, between #6 and #8, since the same head is used on both sides.
mike24
08-07-2002 10:06 PM
