95 z28 sed light on and fans runnung
I have a 95 z28 hat has the sea light stuck on and also both low and high speed fans kick on when started. I have a cable ordered to check codes I have checked the air pump fuse is tithing else I can check or any ideas of what can be wrong since it is my d.d. Thanks in advance for any help
Re: 95 z28 sed light on and fans runnung
"SES" light may be for coolant temp sensor, or possibly a few others that turn on the fans when the code sets.
Courtesy of Shoebox
4th Gen LT1 F-body Tech Articles
Reading the codes, as you plan to do, is easier than guessing. Not sure what "AIR pump fuse is tithing" means.
Courtesy of Shoebox
The coolant temp sensor is new. Just repaired intake leak about a month ago it is so nice to drive and not have to smell burnt oils the whole time. Is there any way to read it besides a laptop and the program that is on here for 93-95 camaro. It runs good I hate to see that light because I'm driving it and I know something is wrong with it
Find an old Auto X-ray OBD-1 scanner, a used or Chinese ripoff Tech-1 or 2, or buy a dual capability OBD-1/OBD-2 scanner from Actron. Do not buy a dual capability scanner from Equus or Innova. Their code data base for the LT1 is screwed up and will give you a list of about 7 bogus codes.
Make sure it has the correct cable for your 16-pin DLC connector. If you find the Auto X-ray it may have an adapter. If not you can jumper the pins per Shoebox:
http://shbox.com/1/xraycable.jpg
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
You can't beat the price on the Actron CP9185 right now at $65 on Amazon (US)
And since you have a 95, you will not need the optional CP9127 cable set.
