95 z28 radio wiring diagram?
i bought a 95 z28.. The previous owner installed a kenwood radio.. The radio will stay on until the passenger door is opened and key off. When it shuts the radio all all the presets erase and settings as well.. i need a wiring diagram.. I already checked shbox.com but could locate one... Any help would be appreciated
Re: 95 z28 radio wiring diagram?
Looks like the previous owner did not hook up the memory wire
on the back of the radio there is a wiring diagram ... find the memory wire on radio
tie it in to the harness .. use a test light to find the constant hot wire from the dash boards wiring harness if my memory is right its the larger yellow wire
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
The always-hot (memory) wire is orange. The switched wire is yellow. Shoebox has a diagram for the 96. I noticed it is identical to the one in the 94 manual so it should be good for 95 also.
01-05-2015 07:14 PM
Brandon Wittmer
12-03-2014 09:28 PM
07-04-2005 05:00 PM
