95 z28 anti theft - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 02-28-2014, 03:59 AM   #1
95 z28 anti theft
i replaced engine with another lt1 from 95 z28 and i have that cars steering column and key and computer so am i gonna have a problem with that anti theft device cause im hearing that i will not get car to run cause of that
95z28_396LT-1 is offline   Reply With Quote
Old 02-28-2014, 10:09 AM   #2
Re: 95 z28 anti theft
You don't need the steering column from the other car. Your original key will work fine. The PCM does not care about any key differences-only the VATS module does and you did not change that.
shoebox is offline   Reply With Quote
Old 02-28-2014, 10:12 AM   #3
Super Moderator
You have to keep your original key (unless by chance it matches the resistance of the new key), which involves changing out the lock cylinder in the column for your original cylinder, allowing you to use the original key. Or you could bypass the security system with a resistor equal in value to your original key.
Just curious... why are you changing out the entire steering column?
Read Shoebox's description of how the security system works:
4th Gen LT1 F-Body Tech-PassKey/VATS
4th Gen LT1 F-body Tech Articles
http://shbox.com/1/vats_bypass.jpg
Injuneer is offline   Reply With Quote
Old 03-02-2014, 08:27 PM   #4
Talking Re: 95 z28 anti theft
Quote:
its not real hard to bypass it should you need to.
Fred Holz is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
1996 Chevy Camaro Z28 SS w less than 19k org. miles F'n1996Z28SS Cars For Sale 6 04-02-2015 11:02 PM
Intermittent ignition/fuel 97Z28Muscle Fuel and Ignition 2 02-06-2015 11:44 PM
LT1 engine swap help needed. 1996 z28 motor/trans into 1995 z28 dbusch22 LT1 Based Engine Tech 2 01-05-2015 08:14 PM
97 V8-6SP into a 94 Z28? what to expect? cmdeshon LT1 Based Engine Tech 2 01-04-2015 12:15 PM
Very disapointed about seeing this.... GC456 Site Help and Suggestions 2 08-09-2002 12:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
