94camaro wheel bearing
#16
#17
Re: 94camaro wheel bearing
You need to check the brake pads. When you go around a corner, the axles move slightly side-to-side. This can cause the metal finger on worn brake pads to contact the rotor and "squeak" or "screech", depending on how worn the pads are.
Since it's a possibility, it's worth checking.
#18
close call today i think that squeaking and squeeling was coming from this, it has been touching the hot pipe and burning... my car could of kilt me good thing it didnt.. what is this part called and is it a hard job to replace? seems like a plug and play type.
#20
Fuel feed and return lines melting on the AIR pipe? There should be a clip (GM #12048089, often broken, #42 in the diagram below) on the side of your TB cover that keeps the lines away from the AIR pipe.
GM PART # 10258441. Not real expensive. Comes as a bundle of 3 lines. Fuel feed, return and EVAP. Quick connect from under the driver's seat floor to the engine compartment. You'll need access into the wheel well area and under the car.
#21
#22
#24
Still a bit unclear to me how the fuel line bundle was causing "squeaking and squeeling" that you mistook for wheel bearing problems, with the noise coming from the rear of the car.
#25
well it was coming from the front drivers side, originally and then i heard it in the back. yesterday it was squeaking really bad in the front drivers side and i opened the hood to find that. So i am thinking that is what the problem was to begin with.
#26
drove my car today and im still getting the noise from the front drivers side so hopefully its brake pads going to check it out more after this snow clears.
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
