94camaro wheel bearing
Old 02-26-2015, 05:32 AM
  #16
Re: 94camaro wheel bearing
Originally Posted by warmeck
so your saying this is normal and i shouldnt worry about it?
No, I am not saying that. I am saying if there is noise from the LSD, it probably needs some additive (to function properly).
shoebox is offline
Old 02-26-2015, 07:39 AM
  #17
You need to check the brake pads. When you go around a corner, the axles move slightly side-to-side. This can cause the metal finger on worn brake pads to contact the rotor and "squeak" or "screech", depending on how worn the pads are.
Since it's a possibility, it's worth checking.
Injuneer is offline
Old 02-27-2015, 02:51 PM
  #18
warmeck's Avatar
close call today i think that squeaking and squeeling was coming from this, it has been touching the hot pipe and burning... my car could of kilt me good thing it didnt.. what is this part called and is it a hard job to replace? seems like a plug and play type.
warmeck is offline
Old 02-27-2015, 02:57 PM
  #19
warmeck's Avatar
warmeck is offline
Old 02-27-2015, 04:57 PM
  #20
Fuel feed and return lines melting on the AIR pipe? There should be a clip (GM #12048089, often broken, #42 in the diagram below) on the side of your TB cover that keeps the lines away from the AIR pipe.
GM PART # 10258441. Not real expensive. Comes as a bundle of 3 lines. Fuel feed, return and EVAP. Quick connect from under the driver's seat floor to the engine compartment. You'll need access into the wheel well area and under the car.
shoebox is offline
Old 02-27-2015, 05:06 PM
  #21
warmeck's Avatar
could i get this at autozone? looking for a quick repair, and do u have a how to on this or no?
warmeck is offline
Old 02-27-2015, 08:43 PM
  #22
The GM parts will come from the dealer. Not aware of any aftermarket replacements. No how-to, but it should be pretty straight forward.
shoebox is offline
Old 02-28-2015, 02:13 PM
  #23
warmeck's Avatar
thanks problem solved was an easy fix!!
warmeck is offline
Old 02-28-2015, 02:37 PM
  #24
Still a bit unclear to me how the fuel line bundle was causing "squeaking and squeeling" that you mistook for wheel bearing problems, with the noise coming from the rear of the car.
Injuneer is offline
Old 02-28-2015, 02:43 PM
  #25
warmeck's Avatar
well it was coming from the front drivers side, originally and then i heard it in the back. yesterday it was squeaking really bad in the front drivers side and i opened the hood to find that. So i am thinking that is what the problem was to begin with.
warmeck is offline
Old 03-01-2015, 02:55 PM
  #26
warmeck's Avatar
drove my car today and im still getting the noise from the front drivers side so hopefully its brake pads going to check it out more after this snow clears.
warmeck is offline
Old 03-08-2015, 08:01 PM
  #27
warmeck's Avatar
brake pads are worn thin lol going to replace them asap!
warmeck is offline
10-31-2016 11:09 AM
grabbem88
20
12-27-2015 07:42 PM
KYWes
04-15-2015 07:28 PM
akwa
04-05-2015 05:09 PM
Quick Reply: 94camaro wheel bearing
