94 Z28...went out started it, zero oil pressure???
Old 06-16-2016, 09:40 PM
90rocz's Avatar
Started the Z a couple of days ago and zero oil pressure...drove fine the night before.
Removed the sender and started it...no oil came out.
Replaced the oil pump....stuck the drive shaft in the pump drive and rocked it both ways...not stripped...gears appear yo be meshing great from the crank side looking up.
New melling pump...still zero oil pressure.
Could the gear on the cam be free spinning?
90rocz is offline
Old 06-16-2016, 09:42 PM
90rocz's Avatar
Re: 94 Z28...went out started it, zero oil pressure???
It rattles...there is zero oil flow
90rocz is offline
Old 06-17-2016, 04:34 PM
90rocz's Avatar
Solved....stripped oil pump drive gear in one small section
90rocz is offline
truthmatters
3rd Gen / L98 Engine Tech
08-19-2015 04:09 PM
cmsmith
08-17-2015 06:50 PM
KYWes
08-04-2015 01:54 PM
Nickster 7
05-01-2015 09:04 PM
Quick Reply: 94 Z28...went out started it, zero oil pressure???
