94 sash channel broke
Old 03-19-2014, 06:19 PM
btate868's Avatar
hey gents, I have a question. The part(sash channel I believe its called) that holds the bottom of the window to the rail in side the door which always fails on this model broke on mine recently and I can not find a spare window anywhere.
Im in the process of rigging something up that seems like it will work but are there any other ways people have found to fix this issue other than finding a new window or getting the old one welded?
I called a few welding shops and was told two things. That metal is so thin it may just melt off when they put the torch to it and the other place said that windows can shatter if a spark touches them so they said its not a good idea.
My work around was to just fix the a/c so I didnt have to mess with the window right now with school but I must have a leak because I had cold air for about 3 weeks after the recharge and now its back to hot air so its back to fixing the window. thanks for any help in advance. Also if anyone has or knows where a new window is id be happy to purchase it if I need to.
btate868 is offline
Old 03-23-2014, 01:34 AM
Fatdog2's Avatar
Re: 94 sash channel broke
Might ask Shoebox on this on.Are you talking about the rail that holds the glass or the arm thing?If your air conditioning is getting hot after a freon charge,then you have a leak.I.ve never seen anybody weld anything in the door.Keep posting,you should get some answers.My02.
Fatdog2 is offline
Old 03-23-2014, 12:17 PM
4th Gen 4 Life's Avatar
I have the parts you need. I also have both driver and passenger window. Post a picture exactly what you need and i can verify on the doors if it can be fixed or if a whole window is needed.
Brian
94 Z28 4l60e. Reworked heads ported and polished. Cam 3" catback flowmasters. And common bolt ons.
Any help or advice i give is my 2 cents and is based on my experience with the F-Bodies. As always seek professional help for certain problems.
4th Gen 4 Life is offline
Old 03-23-2014, 12:29 PM
Jon eds's Avatar
OK I did this on mine cause mine broke as well.. I took a small drill bit.. Sorry don't remember the exact size and used a tap to make a while to put a small screw with several washers since I couldn't find one short enough.. It has held up in mine so far... The piece is very small so take ur time and use s vice or something to keep it from spinning as u drill/tap the hole
Sent from my SCH-I545 using Tapatalk
Jon eds is offline
Old 03-23-2014, 05:59 PM
glass man's Avatar
Remove window from sash channel then have the post welded put wet rag around post n cover nylon roller when welding cool quick after then rerivit 2 window might need glass shop 4 install easy way is w/sash on regulator already in door
glass man is offline
Old 03-31-2014, 08:57 PM
Fly Z28's Avatar
I second what glassman said. About a year ago my driver door window motor went out and the roller was broken off. I had taken it to a real good auto glass shop, in business for 50+ years with very skilled guys. They removed the window and drilled the rivets out. I then had the roller stub welded in proper place and they re installed it. It works great now.
Fly Z28 is offline
truecontr3
10-11-2015 09:30 AM
DelSoto
09-19-2015 05:31 AM
Daluchman1974
09-11-2015 06:12 AM
Bxlt1
07-18-2015 02:48 PM
Quick Reply: 94 sash channel broke
