Ignition key lock question
Old 03-31-2014, 02:14 PM
NJ-LE's Avatar
My ignition key (spare key too) is taking extra effort to insert into the switch. I was going to use some graphite lock lube (powdered kind) but remembered the security resistor pill. Is it safe to use the key lube or will it change the resistance measurement enough to cause a security error? Has anyone used any other key lock lube?
NJ-LE is offline
Old 03-31-2014, 04:42 PM
Re: Ignition key lock question
I wouldn't worry about it. Apply the graphite to the serrated end of the key, and inset it. Repeat until "smooth". Then take a Q-tip (flatten as required) or similar, with some alcohol on it, and insert far enough to swab the contacts for the resistor pellet.
Injuneer is offline
Old 04-01-2014, 07:44 AM
NJ-LE's Avatar
Thanks for the reply. I think I'll try a pipe cleaner for clean out to avoid any cotton from a Q-Tip being left behind.
NJ-LE is offline
liamcg97
11-25-2019 05:55 PM
10-31-2016 11:09 AM
cyteone
02-07-2015 06:04 PM
Dzmaro
01-25-2015 10:39 AM
Oncomingstorm22
01-22-2015 07:15 PM
Quick Reply: Ignition key lock question
