94 lt1 lost throttle power
Hey I'm STUCK ON SIDE OF THE FREEWAY. I was for about 2 hours on the highway with perfect running condition. Suddenly I notice I was pushing the gas all the way to the floor. An more I gave it gas the slower the car got. I came to a stop an cut the car off. Now IT STARTS AN DIES ONCE I TOUCH THE GAS. 113k miles NEVER HAD ANY ISSUES B4 #IM STUCK AS OF NOW. Please help
Re: 94 lt1 lost throttle power
I just bought a fuel pump pressure tester at Harbor Freight for $17.00 with a coupon.Haven't had time to try it out yet(this is uncharted territory for me)but learning from this forum and watching u-tube(especially the vette guy) I think I will give it a go one of these days.Anyway,I would put die-electric grease on both ends of the coil wire and clean up the coil terminal before installing the wire.Hope this helps.
This is the flexible part of the line in front of the filter.This should have made a mess.When was the last time the fuel filter was changed?I ran a fram filter just to capture a lot of crap in the tank then put on a ac delco filter.My car sat most of it's life before I got it.Hope this helps.
http://shbox.com/1/fuel_filter.html
And you actually heard the pump run for 2 seconds when you turned the key to run?
Most likely your check engine light is on. If it's not it will be if the motor runs like poo. First things first is unhook the battery to "reset" the cars computer. The check engine light should only come on for a second then go off. If it comes right back leave the battery unhooked ling enough to get the service engine soon light "same thing" to turn off right after the car starts up no matter how badly you think it runs the cars computer should be in limp mode. Mass airflow sensor is the most common thing to die first or give problems all of a sudden. Your fuel pump should be audible meaning it should make noise for a few seconds after the key is turned to the on position. If you hear it, chances are it's probably OK.
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
mike24
08-07-2002 10:06 PM
