'93 z28 won't idle, engine shuts off!!
Just got a '93 camaro z28 with a LT1 engine in it. Will start but have to pump the gas like crazy to keep it going. previous owner said it had a fuel problem. Any ideas where to start?
Re: '93 z28 won't idle, engine shuts off!!
1: Scan it for codes - easy on a 93, short the pins in the data link connector.
2: Check the fuel pressure - A) turn key to run, the pump will prime for 2 seconds and shut off. What is the pressure when it shuts off? How fast does the pressure drop? B) start engine, take vacuum compensation line off the fuel pressure regulator, plug end of line to prevent vacuum leak. Fuel pressure shoul be 43.5psi (anything in the range of 41-47psi is OK. C) while idling reconnect the vacuum line, pressure should DROP about 8psi. D) If you can keep it running, tape the gauge to the windshield, take it out on the road under max load, WOT at 5,000 RPM. Pressure should not drop below 40psi.
3: If no codes and fuel pressure is OK, download Scan9495 (also works on 93), data log the ECM and one of us will review the data log for you, See "sticky" post on "Computer Diagnostics......" forum.
Pumping the throttle while cranking the engine doesn't do anything except flap the blades. Doesn't result in more fuel. Holding the pedal down puts it in "clear flood" mode, if the engine is flooded with fuel.
Pulling the codes takes a paper clip and ten minutes:
Courtesy of Shoebox
http://shbox.com/1/dlc2.jpg
Courtesy of Shoebox
Appears "Donovan Ferrel" signed on late on 09-05-2016 and read post #7, and never signed onto the site again. Would be nice if people would follow up with feedback, to build a meaningful "knowledge base", but I guess that's asking a bit too much.
alex5366
06-14-2015 10:31 PM
LimitedEd1LE
05-18-2015 01:24 PM
redzed
12
08-29-2002 02:22 PM
