weird engine light problem
Old 07-02-2014, 05:05 PM
chevyguy96's Avatar
Alright so I got a 96 camaro z28, nothing crazy mostly stock. But the issue I'm having is that when the service engine light is ON it runs fine, never dies, stutters or anything. And when I turn the light OFF it dies randomly until the light comes back on. The code it brings up is the crankshaft position sensor A But I changed it twice, had a shop look at it and nothing....any help?
chevyguy96 is offline
Old 07-02-2014, 05:20 PM
Re: weird engine light problem
The crank sensor is only there for misfire detection. But it needs the data from the cam position sensor in the Opti to do the misfire calculations. Sometimes, a corrupt cam position signal will cause the CKP sensor codes.
The mystery is why it runs better with the CKP codes set... the factory manual does not indicate any actions when the code sets that would affect engine operation. I'm wondering if you have a problem with an erratic high resolution pulse signal from the Opti, and when the CKP codes set the PCM defaults to using only the low resolution pulse signal.
Just for the hell of it, check the short Opti harness for corroded or damaged connector pins, a broken clip that holds the connector on the Opti, or some missing insulation on the harness wires.
Injuneer is offline
Old 07-02-2014, 10:35 PM
chevyguy96's Avatar
Well I just replaced that opti, put an msd opti in with wires and coil. So I don't know if it would be corroded but il look and see. Ya it's definitely weird how it runs good with the light on and not with it off
Old 07-03-2014, 09:56 AM
I have just sorted out two cases of people with surging problems, both of them with the MSD Opti. Problem is erratic high resolution pulse signals. One of them just had his MSD rebuilt for the second time, installed it, and had the problems from the first turn of the key. Second guy had his MSD for a couple years.
I personally would even think of buying an MSD..... the only thing you get for the extra $$$$ is extra problems.
Injuneer is offline
bfmv13trivium
01-14-2015 09:57 AM
dirtybird81
10
01-06-2015 09:31 PM
01-05-2015 07:14 PM
cmdeshon
12-27-2014 10:06 AM
07-04-2005 05:00 PM
Quick Reply: weird engine light problem
