93 trans am overheats
Old 11-18-2013, 06:57 PM
jb4xx's Avatar
Recently purchased low mileage 93 trans am. Temp guage was not working so we changed sensor when doing opti replaced. Temp creaps up to red at lights, got stuck in traffic and had to pull over and turn it off. Going down the road, temp indicates 220. Just flushed coolant several times and have same results.
Fans come on when obd ports are jumped. Fuse is good, tried swapping relays, still no fans with temp all the way to red zone.
What am I missing???
jb4xx is offline
Old 11-18-2013, 08:25 PM
Re: 93 trans am overheats
I assume you changed the coolant temp sensor in the head, since you indicate it fixed the gauge. What about the CTS sensor in the water pump for the ECM? Have you scanned the ECM for codes?
Injuneer is offline
Old 11-18-2013, 08:33 PM
jb4xx's Avatar
No codes when jumped the pins tonight, fans came on when jumper was in.
Changed both sensors, even put old sensor back in water pump and had same results
jb4xx is offline
Old 11-18-2013, 08:44 PM
moparman's Avatar
It's normal for these cars to heat up when stopped or creeping in traffic. Fans should come on right about the third hash mark. Depending on ambient temp, 220 might not be to high driving down the road.
moparman is offline
Old 11-18-2013, 09:51 PM
jb4xx's Avatar
Turned the car off as it reached the line where the red. Didn't want to damage the engine
jb4xx is offline
Old 11-19-2013, 06:53 AM
I would check the accuracy of the coolant temp sensors:
Courtesy of Shoebox
4th Gen LT1 F-body Tech Articles
Do you have access to scanning software that would show the temperature being reported to the ECM, and whether it is commanding the fans on - 1st fan at 226*F, second fan at 235*F?
Injuneer is offline
Old 11-19-2013, 08:36 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Like Fred suggested, get it scanned to see what the PCM sees as engine coolant temp. A bad connection in the wiring to that sensor can make the reading much lower than real and that might never turn on the fans. You can use free TunerProRT and the 93 definition file (da2.ads) to scan the readings, but will need an OBD1 cable.
GaryDoug is offline
Old 11-23-2013, 09:32 PM
jb4xx's Avatar
Anyone in the Louisville ky area have a obd1 scanner?
Saw a usb connection obd1 for $59. Is there a cheaper option?
jb4xx is offline
Old 11-23-2013, 09:55 PM
Prominent Member
GaryDoug's Avatar
$59 is about as low as I have seen. You can make your own for under $20, but you have to order the materials on ebay from China (2 weeks) and it requires a small amount of electrical familiarity, like splicing wires and such. See this topic:
https://www.camaroz28.com/forums/com...95-lt1-874306/
GaryDoug is offline
Old 11-25-2013, 08:48 PM
moparman's Avatar
What part of town are you in?
moparman is offline
Old 11-26-2013, 04:06 AM
jb4xx's Avatar
20 minutes away in Indiana
Work in east end.
jb4xx is offline
Old 11-28-2013, 07:33 AM
moparman's Avatar
Here's a link to a local board. I know there are some guys in southern Indiana that might be able to help. Join up and ask.
F-Bodies Unlimited Message Board - Powered by vBulletin
moparman is offline
Old 12-01-2013, 10:09 PM
jb4xx's Avatar
My son attends. Diesel tech classes at local high school vocational school. His teacher asked if ac was charged. I thought, it shouldnt matter. I charged the ac until compressor kicked on and fan came on. I turned the ac off and let it idle and sure enough the high speed fan kicks on just as the guage enters the red zone!
The fan stayed on until temps were half way between the 220 and red zone
I'm thinking about installing different ect to trigger fans at lower temps. Override switch would be last resort. May replace radiator, who knows how much its blocked up. 20 year old radiator with only 56 thousand miles, car sat around a lot the last 10 years.
jb4xx is offline
force10
08-10-2015 08:30 AM
dolfan324
07-17-2015 10:34 PM
Fastbird93
07-11-2015 04:37 PM
Jmj93z28
07-08-2015 06:58 AM
Campbellb48
07-05-2015 06:31 PM
Quick Reply: 93 trans am overheats
