93 speedometer correction
After months of trying to correct the speedometer on my 93 6spd, I found a solution. A truspeed calibrator by Superlift.(The 4x4 people) They will correct up to 28%. Just splice into VSS wire on back of computer, plug "D" it's brown, pin 8 grn/white. Watch out for pin 7, same color. it controls fuel pump relay, guess how I found out. Any way hope this helps.
It was 169.95. I got it from JCWhitney, but they are all over.(anyone who sells superlift over the counter) I just threw the box away, but the application is for 92-current GM truck SUV. It has real good directions. It adjusts with a reostat up to 28%. Mine was right at 27%. I went from 2.73 to 3.73. Let me know if you have any more questions.
It has 4 wires. Red=switched 12v, black=ground, green=vss wire towards computer, yellow=vss wire towards main harness.
Vss wire located in brown plug" D" pin 8 on back of computer.
I'm not sure what resistance their rheostats have to be accurate and computer friendly.
Aaront810
08-29-2020 09:34 PM
