93 camaro z28 Problem with speedometer!!!!
Old 11-11-2013, 04:15 PM
alienman86's Avatar
Unhappy 93 camaro z28 Problem with speedometer!!!!
I have a problem with my speedo. when the car is idling its find it sits at 0 then you rev the motor it moves and when you put it in gear the speedo goes to 150mph? please help thank to anyone that can help i can take a video too if anyone needs one.
alienman86 is offline
Old 11-11-2013, 06:07 PM
alienman86's Avatar
Re: 93 camaro z28 Problem with speedometer!!!!
Its a 1993 camaro z28 a/t lt4 with some mods.
Old 11-11-2013, 08:20 PM
alienman86's Avatar
can it be the computer going bad?
Old 11-12-2013, 07:31 AM
The 93 factory manual is contradictory with regard to the speedometer operation. In one place it describes a "VSS buffer" located in the under hood convenience center. The buffer is the device that converts the VSS output to the signal required by the speedometer. If that is correct, 1993 would be the only year that uses this configuration. Later years feed the VSS signal to the PCM, and the PCM drives the speedometer. 93 is different in many respects, with the tachometer driven directly off the coil, via a filter, where other years drive the tach from the PCM.
Yet elsewhere in the factory manual, the wiring diagrams show the VSS signal splitting and feeding both the ECM and the speedometer/odometer section of the cluster, and do not show a buffer.
Look in the under hood fuse/relay box to see if there is any indication of the VSS buffer.
Could be the VSS, could be the buffer (if it exists), could be the speedometer or could be high voltage interference on the VSS signal wires.
Injuneer is offline
Old 04-08-2014, 11:12 PM
alienman86's Avatar
Ok there is no speed buffer I will put a video up with a link to youtube
Old 04-08-2014, 11:35 PM
alienman86's Avatar
ok here is the link for youtube guy let me know what you think,
Old 05-29-2014, 08:02 PM
Z28barnett's Avatar
I have a version of this problem.
Started the car to day with the wheels chocked and parking brake on.
When I rev the engine to 3000 rpm the speedo goes to 10mph with the car sitting still.
1995 Z28 lt1 6 spd.
Anybody fixed a problem like this? ECM bad?
Z28barnett is offline
Red Hawk 94
03-18-2019 04:03 PM
Brandon Wittmer
12-03-2014 09:28 PM
siguy
11-27-2014 10:07 AM
grendal
04-15-2010 05:20 PM
2000silverz28
07-20-2002 06:14 AM
Quick Reply: 93 camaro z28 Problem with speedometer!!!!
