NOOB could you point me in the right direction
Old 01-05-2014, 12:38 PM
Ybodymarro's Avatar
I am a New to the Camaro's
I wanted advice on building my Car to perform to its best potential
I bought a 1995 z28 with a top end work and stock lower
six speed
IT has Elliot works LE1 ported heads
226/232 .578/.574 110 LSA. – 1900-6200 RPM Cam
1:6 rockers
Forged push rods
30lb injectors
Long tube headers-wrapped
Flowmaster full exhaust
KN cold air intake
Kevlar Clutch
IT was Dyno at Kennedy Dyno in western ny and it had notes on the Dyno sheet. Small oil leak and spark plug wires installed incorrectly
The car was running ****ty misfiring bogging down and choppy when I got it.
We sorted the wires out and it ran much better
But I still need to adjust the roller rockers because some are sloppy and some are too tight.
Basically my questions are
-What HP should I expect from this Build?
-Will my money be well spent taking it to my local dyno and having it retuned after I go and double check everything?
-Is weight savings my best next step in the process?
-Are sub frame connectors a waste of money on a car that is stock lower?
-What can I do to get good break performance for the track. The stock breaks are crap.
Ybodymarro is offline
Old 01-05-2014, 02:44 PM
Super Moderator
JakeRobb's Avatar
Re: NOOB could you point me in the right direction
Everything depends on your budget and goals, except one thing: get the subframe connectors.
JakeRobb is offline
Old 01-06-2014, 10:50 PM
bobdec's Avatar
As far as HP... LT1 LE1 «
Tuning is key, if you can't DIY then yes, have it done after the plug wire repairs.
bobdec is offline
Old 01-07-2014, 04:31 PM
parkers Z28's Avatar
The T top car really needs the sub frame connectors.... LS1 Brake up grade for cheap
just curious what is your goal for this car weekend warrior? daily driver ? track car?
the link above shared by bobdec says 360-380 capable of up to 400hp
parkers Z28 is offline
meissen
06-01-2015 07:59 AM
Z28Freak86
04-28-2015 10:35 PM
cmdeshon
12-27-2014 10:06 AM
Deadbolt24
12-18-2014 08:18 PM
Sarahrope64
11-27-2014 11:17 AM
Quick Reply: NOOB could you point me in the right direction
