i need help with removing my G2 performance by giglotti rear end Axel shaft
Old 01-20-2014, 09:27 PM
martinezdal's Avatar
OK im having trouble removing the rear axle shaft because I'm trying to install longer wheel studs.....I have called several mechanic buddys of mine and they can't figure it out I took off the 10 bolt cover off and removed the 8mm side slide pin bolt and nothing I can't get it to come loose.
martinezdal is offline
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
Chet1185
02-04-2015 09:51 PM
jcamaro95lt1
01-24-2015 08:21 AM
nodnarb481
Middle Atlantic
01-01-2015 11:43 PM
Quick Reply: i need help with removing my G2 performance by giglotti rear end Axel shaft
