4th Gen Power Window Control Module
Somebody recently bought one off of me, before I send the part out I want to make sure its correct.
The part number on it is 12088537, did GM change part numbers on this item? The part number comes up as nothing when doing a search on gm parts direct and it is not the current part number of the item. It looks exactly like the module but just want to make sure.
Re: 4th Gen Power Window Control Module
Numbers that are stamped or cast into items are not always valid as part numbers. Unless someone can look at theirs and verify it has the same exact number, there is no real way to tell if it is correct.
dluna333
15
03-13-2015 12:30 PM
