3rd Gen Electrical question
Ok my car is at a garage getting work done, one thing is setting the radiator fan back up so it comes on at a certain tempature.
Right now the fan is controlled on the AC controls(there is no AC) You put the AC on max and the radiator fan goes on, thats it.
The mechanic is having a hard time figuring out whats up here. I know this was done buy the previous owner so I'm wondering if this is a somewhat common thing with a common system as to how its done, anyone got any guesses?
Re: 3rd Gen Electrical question
single fan was controled by the A/C controls and a switch in tha passenger cylinder head, dual fans had one same as the single, and one controlled by the ECM
Yep, Dave89IROC is right. The problem is either the coolant fan switch or the wiring to it. The fan switch is located in the passenger side cylinder head, in between the #6 and #8 spark plugs. It's not uncommon at all for those switches to go bad over time or have a problem in the wiring. I've seen it happen a lot (not to mention I've replaced mine 3 times ).
Although, now that I think about it, how hot has the car been ran? Just curious because the stock fan switch on the single fan cars is rated at 238*. I have still yet to figure out why GM made the fan come on so late.
I didnt get a chance to feel smart cuz already replaced the switch and got it working when I called.
Changed all the fluids
installed a trans and torque converter
repaired electrical wiring to rad fan and interior lighting
new starter
new alternator
1300 bucks, woohoo!
new starter
new alternator
1300 bucks, woohoo!
ChrisFrez
12-21-2014 09:47 PM
07-04-2005 05:00 PM
stars1010
07-15-2002 03:51 AM
