2002 Camaro 3.8 idle Help!
Ok so I have a 2002 Camaro 3.8 and these are symptoms im having and shat ive done to car
Car runs like total **** , huge power loss , coolant fans stay on from start up , coolant temp guage is dead which is leaving the check engine light on! :banghead:
Symptoms
-idles stays stuck at 1500 for a few seconds ( 10- 15s ) after im fully stopped
- im getting engine light (code p0128) shows 2 times
- when in gear car sputters like its running out of gas unless I turn a/c on then it will stay on , will idle a lil better in neutral or park
(Used to throw MAF code but I no longer get it with new one or old one)
Things ive done recently
- plenum gasket
-Maf
- oil
-coolant
-water pump
-coolant elbows (aluminum)
What ya guys think ? :what:
So far people are giving me 3 major things
-Egr valve
-Catlyic converter
-Pcm (computer)
Which all sound wrong any one have input or suggestions?
Sent from my SGH-M919 using Tapatalk
Symptoms
- plenum gasket
-Maf
- oil
-coolant
-water pump
-Egr valve
-Catlyic converter
-Pcm (computer)
F'n1996Z28SS
08-23-2023 11:19 PM
