2001 Camaro stock front rotor diameter?
Old 05-04-2013, 08:06 AM
SteveC's Avatar
Exclamation 2001 Camaro stock front rotor diameter?
Could someone please tell me the stock diameter of the front rotors?
I am interested in a aftermarket rotor, that does not change the stock position of the brake caliper.
Thanks in advance;
SteveC
SteveC is offline
Old 05-04-2013, 10:01 AM
bobdec's Avatar
Re: 2001 Camaro stock front rotor diameter?
98+ CAMARO BRAKES “LS1”:
Rotor Size: 12 inches
Rotor Thickness: 1.25 inches
-Caliper specs
Piston size: 1.75 inch outer diameter
Total pistons surface area: 9.62 square inches
Material type: Cast Aluminum via gravity cast
bobdec is offline
Old 05-04-2013, 11:08 AM
SteveC's Avatar
Thumbs up Re: 2001 Camaro stock front rotor diameter?
-Caliper specs
Thank you very much.
SteveC is offline
Jazsun
12-29-2014 12:14 PM
hotrodyou1
12-20-2014 10:05 PM
07-04-2005 05:00 PM
Geeterman
08-04-2002 04:03 AM
Quick Reply: 2001 Camaro stock front rotor diameter?
