2000 Z28: Security light on dash
Moved to General Tech. You will have better luck getting an answer here, as the problem is not engine related.
Generally this has something to do with the VATS system, which is the little chip in the ignition key (and the part of the car that reads it). I'm afraid I won't be of much help personally, but if you search this forum for VATS, you'll probably find some helpful advice.
yep its a vats prob
Without a code reader that can access the bcm its impossible to know for shure, but usually it means that the BCM is not reading the correct or any frequency from the key
try usuing a eraser on the keys chip this sometime helps.
Oncomingstorm22
01-22-2015 07:15 PM
fpete1992
12-11-2014 03:51 PM
