How to remove a small exterior panel?
Old 07-30-2014, 10:29 AM
Z4Ccoupe's Avatar
I am working on my 96 and I want to remove the small triangular black panel right behind the doors on each side. Does anyone know how it is attached and what I have to do to pull it? Thanks.
Z4Ccoupe is offline
Old 07-30-2014, 11:48 PM
Z28SORR's Avatar
Re: How to remove a small exterior panel?
I checked my 97 manual and can only find a reference in the convertible section.
However on the coup there is a "roof side window weatherstrip retainer" at this location that is held in by two screws. They may hold this panel in as well.
You may want to check with a friendly body shop and see if they can help.
Z28SORR is offline
Old 07-31-2014, 11:25 AM
bobdec's Avatar
from what I read the coup panel is held on by double sided body tape. Convertibles are held on by two screws. The coup needs to be pried off and usually can't be saved. Search on triangular sail panel , not to be confused with the larger sail panel on the roof behind T-tops. There are stock and custom design replacements on E-bay http://www.ebay.com/itm/93-02-Camaro-Firebird-Coupe-Black-Triangle-Sail-Panel-Trim-NEW-GM-PAIR-/321289592835?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACamaro&hash=item4ace5a2003&vxp=mtr
bobdec is offline
Old 08-01-2014, 04:49 PM
Z4Ccoupe's Avatar
Yup those are the pieces. Thanks.
Z4Ccoupe is offline
F'n1996Z28SS
08-23-2023 11:19 PM
Collector Car
01-05-2015 10:58 AM
siguy
11-27-2014 10:07 AM
Darth Xed
13
07-22-2002 12:45 PM
Quick Reply: How to remove a small exterior panel?
