1994 LT1 was the best Year
Old 04-19-2004, 10:41 AM
  #31
GreenDemon's Avatar
95
Or 96&97 due to the fact that the SS was back. Those have got to be my favorite years for the SSs, it seems like they lost some of that aggression when the LS1 SS came out.
GreenDemon is offline
Old 04-19-2004, 03:19 PM
  #32
rpm4lalo's Avatar
95 best for LT1's.
Mine had the hardened pushrods, but I swapped them out for 1 piece hardened trick flow pushrods. The stockers were a two piece welded design, crap in my opinion.
The T56 in the 95 is also rated for more torque than the 93's T56.
rpm4lalo is offline
Old 04-19-2004, 03:34 PM
  #33
MTL_Z28's Avatar
Don't forget the '96's and '97's were dual cat vs. single cat before. Don't know if that makes much of a difference but they are rated 10 HP higher from the factory (285 HP vs. 275 HP for 1995 and before).
MTL_Z28 is offline
Old 04-19-2004, 04:03 PM
  #34
JoeliusZ28's Avatar
95
JoeliusZ28 is offline
Old 04-19-2004, 06:57 PM
  #35
Tang's Avatar
Originally posted by JoeliusZ28
95
Amen brother!
Tang is offline
Old 04-19-2004, 09:44 PM
  #36
Kris93/95Z28's Avatar
Originally posted by lovescamaros25
I think the 94 camaro is the best because the convertible and t-top camaro returned.
The 93 s did have T-Tops as an option.. They are just not as plentiful as the later years.
it got the 4l60e transmission which replaced the 4l60.
Big win there
It also got an optional keyless entry system,better sound system,
You sure about that? Many 94s have the same 3 speaker system as the 93s, wasn't the 3->5 speaker a mid year option?
sequential fuel injection which was a huge improve ment over multi-port.It gave the camaro a smoother idle and also helped reduce emissions.
What? I have NEVER noticed a difference in idle in any year LT1 that was stock cammed... I have driven many, and have many friends with these cars of all years. Also I have never heard of anyone being restriced by the fuel injection setup on a 93, as in they had to switch to a 94+ to get it to run right, Make power, et al.
Kris93/95Z28 is offline
Old 04-21-2004, 08:26 PM
  #37
O-taka's Avatar
94 and 95 Z28s have the nicest ***!
O-taka is offline
Old 04-21-2004, 09:01 PM
  #38
MTL_Z28's Avatar
Actually to tell you the truth I really like the '97 tri-color tail lights...
MTL_Z28 is offline
Old 04-21-2004, 09:18 PM
  #39
kaoshen's Avatar
Don't forget 94+ had the 3.23 Gears on the 6 Speeds
And i think all years had 2.72s on the Autos
kaoshen is offline
Old 04-21-2004, 09:27 PM
  #40
whoa guy's Avatar
Originally posted by shoebox
You mean after 1995. All 1995 LT1 f-bodies were OBD-I.
WRONG! Mine was OBDII. They switched to OBDII later half production. The earlier ones were OBDI
whoa guy is offline
Old 04-21-2004, 09:28 PM
  #41
scoobysnax83's Avatar
I have 3.73's
scoobysnax83 is offline
Old 04-22-2004, 01:40 AM
  #42
MTL_Z28's Avatar
I'm pretty sure the 94+ 6-speeds have 3.42's stock.
MTL_Z28 is offline
Old 04-22-2004, 04:29 AM
  #43
BiGGinZ's Avatar
94+ autos had either 2.73's or 3.23's.
BiGGinZ is offline
Old 04-22-2004, 05:45 AM
  #44
Mtrhds94Z's Avatar
All 95's are OBD I.. They just have an OBD II 16 pin plug under the dash, which leads to the confusion..
Mtrhds94Z is offline
Old 04-22-2004, 01:54 PM
  #45
NOMAD's Avatar
Actually, all 1995 cars were OBDI with an OBDII hook up. All cars made in 1995 for the 96 years were OBDII
-Shannon
NOMAD is offline
Quick Reply: 1994 LT1 was the best Year
