asr problems
Old 01-05-2012, 09:39 PM
97/Z28's Avatar
asr problems
i have a 97 z28 m6 and just recently my "asr off" light keeps turning on by itself. Ive removed the rear abs sensors and cleaned then and still nothing. asr turns off randomly but if i switch it off it will stay off.
97/Z28 is offline
Old 01-06-2012, 05:34 AM
Re: asr problems
There are numerous faults in the EBTCM system that will turn on the light and deactivate the system. Way more than just the rear sensors. Best thing to do is have the ABS/ASR module scanned for codes.
Injuneer is offline
Old 01-06-2012, 11:12 AM
97/Z28's Avatar
Re: asr problems
How do i check it? Using a scanner an connecting it to the obd port?
97/Z28 is offline
Old 01-06-2012, 03:33 PM
Re: asr problems
It takes a high end scanner to read it, typically a GM Tech-2. There have been a couple low cost generic ABS scanners released over the last year that may work with ASR. But it's a different scanner than the PCM scanner.
Injuneer is offline
Old 01-06-2012, 09:56 PM
97/Z28's Avatar
Re: asr problems
thanks for the help! now i have to find someone with a high end scanner....
97/Z28 is offline
Old 01-07-2012, 09:10 AM
Re: asr problems
I suspect Snap-On makes them as well.
Injuneer is offline
1996LT1Z28
04-14-2015 07:15 PM
shroyvin56
04-03-2015 08:15 AM
dluna333
15
03-13-2015 12:30 PM
edman
01-25-2015 02:41 PM
1996LT1Z28
01-14-2015 08:09 AM
Quick Reply: asr problems
