1993 z28 must have a ghost in the motor? HELP - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 04-10-2014, 10:29 PM   #1
Ok I have a 93 z28 had it about a year . I dont drive the car that much it has 91k miles , auto, upgrades are simple. SLP loudmouth catback exhaust and K&n ciold air intake...and here is a list of parts that have been put on in the last 2 weeks.. Opti spark , plugs, wires , fuel pressure reg, fuel pump, map sensor, throttle pos sensor, starter,battery,and water pump.. Ok the car runs great after you get past 2,200 rpm before that it has a hesitation on acceleration.. Like it's not getting fuel..it was doing this before I done the tunup . so now I have it at a local mechanic shop..he's the one who put the fuel pump and tps sensor on..it's still not right and everyone is just guessing.. Even the dealership wanted to throw parts at it ..it did throw a tps code but I never saw the check engine light on he said it was in the memory..ok guys any help would be greatly appreciated this car is driving me insane..also have changed all ground wires and the positive wire to starter...
Ben martin is offline   Reply With Quote
Old 04-11-2014, 10:14 AM   #2
Super Moderator
Re: 1993 z28 must have a ghost in the motor? HELP
You might want to try and run an ECM data log, using the DataMaster software available from TTS Power Systems:
TTS Power Systems
Download, and 20 uses are free. After that, there is a licensing fee. You will need a cable.
Injuneer is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Which AFPR do you recommend? CobraEatr LT1 Based Engine Tech 33 07-24-2004 12:37 PM
Sound Fades In and Out when Car is Started teedoff59 Car Audio and Electronics 0 08-08-2002 02:36 AM
How hard/expensive would it be to pull EVERYTHING and replace with new equipment? CobraEatr Car Audio and Electronics 5 07-29-2002 12:46 PM
Do I need a wire harness when installing my new deck (stock is in now)? CobraEatr Car Audio and Electronics 3 07-23-2002 07:32 PM
What kind of kit do I need to install a single 1 din CD player in my car? CobraEatr Car Audio and Electronics 3 07-22-2002 10:49 AM
Tags
camaro z28, hesitating, rough, stumble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
