1993 Z28 5.7L Optispark Change Help - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 10-13-2013, 03:24 PM   #1
I PUT IN A NEW OPTISPARK ON MY Z28 YESTERDAY IT IS A NON VENTED ONE FOR THE 1993. THE NEW OPTISPARK CAME OUT IF THE BOX READY TO INSTALL WITH GEAR IN IT, PUT IT ALL BACK TOGETHER THE OPTISPARK WENT RIGHT IN AND PUT IT BACK TOGETHER AND IT CRANKS LIKE THE TIMING IS 180 OUT CRANKS HARD, THE ONLY THINGS I CAN THINK OF IS I BROKE THE AIR CONTROL MODULE PLUG, WILL BE REPLACING THAT SOON, BUT YOU TAKE OFF THE COIL WIRE IT CRANKS GREAT. ALL PLUG WIRES ARE RIGHT ALMOST LIKE IT HAS AN AIR LOCK ANY ONE KNOW OF ANY THING I CAN DO FOR IT , I ALSO HAD TO MOVE THE BOTTOM CRANK SOME TO GET THE NEW OPTISPARK IN THAT I HOPE WONT THROW ANYTHING OFF THE CAM AND CRANK ARE ON A TIMING CHAIN. THANKS DAN
supertechdan is offline   Reply With Quote
Old 10-13-2013, 06:02 PM   #2
Super Moderator
Re: 1993 Z28 5.7L Optispark Change Help
You have to index the splined shaft correctly to the teeth in the cam sprocket. While it appears that it can only go in there one way, I'd estimate that about 10% of the installs go wrong and are not indexed correctly.
Courtesy of Shoebox:
http://shbox.com/1/93-94_opti.jpg
You also need to check all your plug wires to insure you have them on the correct Opti terminals.
http://shbox.com/1/opti.jpg
Injuneer is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Which AFPR do you recommend? CobraEatr LT1 Based Engine Tech 33 07-24-2004 12:37 PM
Sound Fades In and Out when Car is Started teedoff59 Car Audio and Electronics 0 08-08-2002 02:36 AM
How hard/expensive would it be to pull EVERYTHING and replace with new equipment? CobraEatr Car Audio and Electronics 5 07-29-2002 12:46 PM
Do I need a wire harness when installing my new deck (stock is in now)? CobraEatr Car Audio and Electronics 3 07-23-2002 07:32 PM
What kind of kit do I need to install a single 1 din CD player in my car? CobraEatr Car Audio and Electronics 3 07-22-2002 10:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
