$1000
Old 04-02-2007, 11:16 AM
pattracing212's Avatar
$1000
i have 1000 to spend.....what should i buy....i can't decide between suspension, n2o, cam, or other little odds and ends.....i haven't been to the track yet so i don't know what i need but i need some input from you guys.
i also need a tune i think...so dyno tune or mail order
pattracing212 is offline
Old 04-02-2007, 11:22 AM
2000GTP's Avatar
With your mods, a mail order tune will be more then adequate. As for the 1K to spend, you'll get alot of varied responses. If you want quick and easy power, a grand can get you a nice nitrous setup with all the extras.
2000GTP is offline
Old 04-02-2007, 11:24 AM
thats what i have been thinking, but how are my 60' times gonna look with stock rear suspension
Old 04-02-2007, 11:37 AM
ZL1modified's Avatar
you already have 1.6's, save up another 200.00 + shipping and get the LE1 package.. just my opinion...
ZL1modified is offline
Old 04-02-2007, 12:28 PM
i have thought about doing the le1 package but i just don't know yet. there is so much more i would need with the package. i woudl need the tune, probably a stall, and suspension to keep the car from spinning down the track. so in all actuallity i would need about 2500 for the le1 package. i just want to know what will give me the most bang for the buck. i know nitrous, but how bad am i going to spin off the line without suspension
Old 04-02-2007, 12:38 PM
if you go nitrous... just get the wot kit and some nice drag radials... should put you in the ballpark... maybe more like 1100-1300... depending on you nitrous setup... i would do a 100 shot...
yea, i forgot about all the extra bs for a head and cam package...
Old 04-02-2007, 01:07 PM
danhr's Avatar
nitrous or save for rear end
danhr is offline
Old 04-02-2007, 02:15 PM
2000GTP's Avatar
That is where tires are going to come into play. All the suspension mods in the world still won't allow you to hook until you have a sticky pair of tires out back.
2000GTP is offline
Old 04-04-2007, 12:30 PM
butterbar's Avatar
but it helps I got lca's and decent tires for just dd, and it helped me stop breaking the tires loose every two secons
butterbar is offline
Old 04-04-2007, 02:12 PM
White96Z28's Avatar
Buy a stall and some drag radials... I wouldn't be suprised if you saw a bigger jump in ET with the stall and tire, than you would with a bottle on it.
White96Z28 is offline
Old 04-04-2007, 02:16 PM
2000GTP's Avatar
In my sig, I have just about every suspension mod out back with the expection of relocation brackets. My car has tightened up quite a bit back there, but I still spin the tires like crazy and can't grip the pavement. After spending a couple thousand on suspension mods, I could have easily dropped my sixty foot times alot more with a converter and drag radials. But that stuff is soon to come as well.
2000GTP is offline
Old 04-07-2007, 03:20 AM
Johnnynsac's Avatar
Buy a nitrous kit and some stickies......then when your rear end grenades park the car unless you have two grand laying around.
Johnnynsac is offline
93 RedBird
11-15-2015 08:24 AM
HibachiZ28
11-06-2015 12:53 AM
tommalcolm
09-11-2015 03:39 PM
smoknta
08-27-2015 05:07 PM
Cbr02
08-24-2015 07:12 AM
Quick Reply: $1000
