wont start or turn over.. Need help
I have a 94 3.4 v6 camaro never showed me any problems.. I went to warm in up next morning, turn the key everything lite up like its normally would and nuthing happend.. I checked and charged the batt, check and replaced the starter and still nothing.. I hear a click sound by the glove box when i turn the key.. What to do..
Re: wont start or turn over.. Need help
Check the battery terminals for corrosion. Check the wires connected to the battery for corroded wire strands.
Is the "SECURITY" light flashing?
There is no corrosion on batt terminals or wire strands.. When key is turned the SECURITY light flashes and then goes out every time i turn the key i hear a click sound that is come from the glove box area.. i hear that the starter relay may be over there.. is that true on my body style.
I have the 94 shop manual, and the only relay in the starter circuit is the theft deterrant relay. If you have bypassed the VATS system with a resistor wired into the steering column wires to eliminate the pellet on the key, you are probably hearing the deterrant relay operating.
Check the fusible link on the red wire from the battery + terminal box to the ignition switch.
One of the reasons we would prefer you not start two different threads on the same topic is that you are getting responses on both of them, and people answering one of them do not see the same info as the people answering the other one:
https://www.camaroz28.com/forums/gen...n-over-844445/
formula79
26
08-05-2002 12:21 PM
