where is my fuel filter?
where is the fuel filter on a 1994 camaro Z28?
i want to try and replace it myself... am i better off spending the extra $20 to have an oil change shop change it?
is there a brand of filter thats recomended by you guys to get? also is there a brand to avoid?
Thanks a bunch!!!!!!!!!!!!
MIKE
MIKE
It should be underneath on the driverside between the door and the rear tire.
I have a 95 Z28 and they did not make much changes between the two years.
They are pretty easy to change out yourself. It should not take more than 5 to 10 minutes. Just be carefull when you remove the fuel lines because the residule fuel will drain out, so you may want to have a small plastic bowl when you change it out.
holy crap are you serious?
you don't know where your fuel filter is?
wow wut a noob!!!!
lol
the answer is yes under the rear passenger seat on the driver side. follow the fuel lines along the car and it's the small can in the line.
every f-body 93-02 fuel filter is pretty much the same and in the same location.
make sure your prepared it's going to spit gas at you.
wow wut a noob!!!!
lol
wow wut a noob!!!!
lol
wow wut a noob!!!!
lol
Two 17mm wrenches will make light work out of it.
Good luck and don't worry about comments from the likes of fellas with "GlowShift Triple Gauge Pods".....:
Dig!,
Ivan
yes I am
( gots nuthin but pos feedback on my install they look great)
Definitely use a line wrench (aka flare nut wrench). Using a regular wrench, it's too easy to wreck things.
If you don't have access to a lift or pit, I'd just get a shop to change it. Getting gas all over your face, eyes, arms....it's not fun.
A shop would take maybe 10 minutes to do it. It's not going to cost a lot to have done.
And people like this is why others don't want to make a post looking for answers, because they might get ridiculed.....
No question is stupid or foolish, just been asked a thousand times in the past, as we all have had to ask at one time or another.....
